drawing index & PDF
    drawing index & PDF
    hello
    is there a any way to create a pdf with the sheet drawing index?
    I'm using PDFcreator to edit my PDF's (and i'm still wandering why Adesk have not create a PDF maker like in ACAD) and the name of my PDF is compound like that : file name - sheet number - sheet name
    impossible to finish the name with the index, is it possible? does dynamo should do a stuff like this?
    thanks
    Phil
    Freelance WWTP/HVAC Designer
    Revit 2019
    If you put your drawing list on a sheet, then print it, Note your sheet doesnt have to have a titleblock.
      hello
      not sure that it corresponds to my desire
      i would like that REVIT add automatically the index at the end of the PDF.
      Phil
      Revit 2019
        Originally posted by philsogood View Post
        hello
        Phil
        Xrev will do it
