Wall location line
    Wall location line
    How come when you click on a wall its properties do not include the wall location line?
    If you are changing a wall type and do not want the internal dimensions of the building to change surely you should be able to access this regardless of whether you want the external dimensions to change?
    It's the first line of the wall properties. Are you seeing something different?
Name:	Wall Properties.PNG
      The grips also show up along the Location Line.
      Dave Plumb
      BWBR Architects; St Paul, MN
        and the flip arrows are always on the exterior side of the wall.
        Jason Coe, Architect
        Beardsley Architects + Engineers
        Auburn, New York
        http://revitecture.blogspot.com
          And the flip mirrors through the location line.
