Project Base Point visibility in Sections
    Hey Everyone,
    I'm looking for a solution for my problem with the visibility of the project base point in a section.
    I have noticed that if the section "looks away" from the project base point, it will not be visible in this view.
    Is it in any way possible to make it visible? (I checked the visibility settings, and hidden objects)
    When we want to submit a building permit application, we need to add a "reference point" to all the drawings, so it has to be visible in every view/section.
    Another question is if there is a way to edit the symbol of the project base point?
    Thanks!
    Originally posted by Tkelly View Post
    Hey Everyone,
    Thanks!
    no and no. A section in Revit sees only what is within it's crop region and I believe that the PBP is hard coded
      Ok. Thanks. Something to keep in mind for future projects!
      Verzonden vanaf mijn iPhone met Tapatalk
