CAD file lines overlap
    Hi There
    Is there any way to make the CAD files line sit beneath the Revit lines when linking a CAD file.
    We have the ID work linked as CAD, objects that sit against the walls, their lines sit above the cut wall lines:crazy:
    Any help would be appreciated
    Thank you
    You can select a CAD and move it to background on the options bar.
    Revit add-ins: Purger (delete UNUSED and selected line patterns & line styles, find & delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager (with bunch of other features) at Revit Exchange Apps, View Filter Manager ML
      Tried that, doesn't work, hence reason for post
        Select the cad in 3D and physically move in down, if it's below a floor finish you shouldnt see it. Well, that's how it works here.
