Coping & Monitoring Grid
    I have a Revit linked file inside my project, I usually copy and monitor the grid for some
    reason this project this project is only able to copy half of the grids. I deleted all the grids
    and tried over again. In my filter when I select the grids shows that I have 113 grids once I
    hit finish only 20 gets copy. Why would this happen.
    the grids need to be shared. If they have 2 grid "types" and one of them is not shared, this would cause the problem
    Simple to fix, open the source file (the linked file) and select the grids that are not copy/monitoring properly, and set them to shared.
    Ask the person that supplies you with the model to make this change for future use.
      Thank you for your help.
