wi9ndow view on plan
    I have a bottom raked window which I am using on a project, but have an issue with its view on the Floor Plan. As the attached images, the window works fine in elevation and 3D view, but on plan view it cuts as shown. I have tried using a "Plan Region: to make it show correctly, but that does not seem to work.
    Does anyone know if I am able to make the whole window show on the plan?
    Jump into the family and change the cut plane height in the ref level plan view to how you would like it represented in the project.
    Michael
    Canberra, Australia
      Thank you Michael for the reply. Can you tell me how to do this, I have looked in the ref level plan, but cannot find how I change the cut view level?
        Sorry Michael, just found it. Had to as you said change the view from family level to floor plan ref level in the properties panel drop down list.
        Thanks again.
          This is why some of us use Generic Models instead of Windows.
          Greg McDowell Jr
          about.me/GMcDowellJr
