Bug when associating parameters of shared nested family
    I finally managed to isolate a bug that has had me climbing up the walls in frustration. Now to see if I can get confirmation on this:
    1 create wall based window family (from factory template)
    2 create shared generic model, create some geometry
    2a create instance length parameters 'associate' and 'result'
    2b create type length parameter 'type'
    2c create formula for 'result' = type + associate
    2d associate a dimension label with 'type'
    4 nest shared family in window family
    5 associate the 'associate' instance parameter of the nested shared family with a parameter in the window family, say 'Height'
    6 load the window family into a project and place it in a wall
    7 group the window and the wall
    EDIT 7a copy the model group to make multiple instances of it in the model (realistic situation)
    8 select the nested family and change type parameter 'type'
    EDIT: I do NOT mean to attempt to switch the Family Type of a family instance outside Edit Group mode. That will not work, and it shouldn't work. I meant: select the nested family instance outside Edit Group mode, click on 'Edit Type', change the Type parameter value of the parameter named 'type' from step 2b.
    9 vigorously scratch head at the warning: Changes to groups are only allowed during Edit Group mode. Use Edit Group to make this change.
    See attached sample rvt, 2016 (version 16.0.1185.0 20161004_0715(x64) Update7 for R2)
    I do not think it is specific for this version, I have been seeing related warnings for months.
    nested shared association bug.rvt
    https://forums.autodesk.com/t5/revit...045106#M148506
    Edit: Some developments over at the other side, no solution as of yet.
    There must be a better way...
    Ekko Nap
    logged as case number 12933832. If anyone has a window family template that I can test for similar behaviour, that would be welcome as well.
    Ekko Nap
      Hi Ekko,
      I think the issue is that length parameters are never allowed to vary within a group - I think this is expected behavior. If you test this you would get the same error.
      1. create a wall
      2. add an out of the box window
      3. group both
      4. make new group instances
      5. select one of the windows and try to change the type.
      Perhaps I'm not testing correctly?
      Glynnis Patterson
      4 Revit Plugins for Precise BIM Data Management | Ideate Software
      Glynnis Patterson, Architect
      www.ideatesoftware.com
        Window & Window Template (zipped) enclosed (both 2016). At the moment I'm not sure if I've done any tinkering with the template file or not but I believe that one is still stock.
        chad
          Originally posted by GlynnisPatterson View Post
          Hi Ekko,
          1. create a wall
          3. group both
          Hi Glynnis,
          In my test, if the change in the type drives a change in the instance through a formula, this message pops up. I'll try your test with Chad's files (Thanks Chad!), but if indeed it does fail, I expect there to be a formula involved like in my example. I'll let you know what I find. Thanks for the contribution. I do hope Chad's window is OOTB? Not sure I installed those myself, must have them around somewhere.
          The thing is, the warning seems the result of some unfortunate regeneration sequence rather then some fundamental logical problem. The whole point of the formula is to combine information from the nested Family Type and the host Family instance, both of which are supposed to always be consistent within the Model Group in the project.
          What I now suspect is that the change in the nested Type DOES trigger the start of a regeneration of all the Nested instances of the modified Family Type, but the first of these regenerations also tries to alter the value of an Instance parameter value (by means of the formula). It is this first change that bumps into the Model Group auditing process that tries to maintain Group consistency. For a change in a Type parameter, the regeneration of the instances within Model Groups is allowed (pending Glynnis's experiment I'll stick with my results for now over the past decade), presumably because the Model Group auditing process holds untill all the instances of the Family Type are regenerated. If the start of the auditing process can be delayed until not just the changes of the Type parameter (and dependent family geometry), but also formula-dependent changes to instance parameters have been processed, the problem would be solved. This actually happens with non-nested families, just not with nested shared families.
          Premature regeneration. I am so coining that one.
          Ekko Nap
            Definitely not an OOTB window
            A few OOTB windows attached. :beer:
            chad
              Hi Ekko,
              Definitely will start using premature regeneration!
              I made a video showing the most basic condition, using OOTB content. Revit just doesn't like changing the type, at least when it is hosted. The same operation would work fine for an un-hosted family that is changed within a group. Seems like a bug to me. Nothing to do with formulas or nesting, just premature regeneration for a hosted family.
              https://www.screencast.com/t/zCFZkO0BBSz
              Cheers,
              Glynnis
                Hi Ekko,
                1. create a wall
                3. group both
                Glynnis Patterson
                You are quite correct that Revit does not allow you to change the Family Type itself if you are not in the group editor. This is normal behaviour IMO. I only realized where the mixup occurred when I actually performed the steps you described.
                The misunderstanding is my fault, I named my Type parameter "type". When I said in step 8 'change type parameter 'type', I meant to alter the value of this Type parameter named 'type', not to attempt to change the Family Type.
                I just tested with Chad's window (Thanks Chad!), and I can indeed not change the Family Type outside the Group Editor. I can change any Type parameter outside the Group Editor, even when I add a formula that combines the changed Type parameter value with an instance parameter value.
                Only once I add a Shared Nested Family to the mix, with in that family a formula that drives an instance parameter, and in that formula I combine information from a Type parameter of the nested Family Type and, through association, from a parameter from the Host Family, things break.
                Last edited by ekkonap; May 5, 2017, 07:46 AM. Reason: Added rvt with Chad's OOTB content.
                Ekko Nap
                  Didn't get a chance to look at your latest upload file, but went back and demonstrated that changing the parameter named 'type' on your nested family is only permitted when it is changed from instance back to type. To me, this is expected behavior: https://www.screencast.com/t/kx6jQDY3Z
                  I was surprised to hear that you can change a type parameter that uses an instance length-based parameter. I believe if the formula has a number, but is not length-based, it would work, but then again, I'm often wrong!
                  Cheers,
                  Glynnis
