Show wall compositions on sheets only if they are referenced in the plan
    Hello all !
    I searched the forum but couldn't find a post even close to this.
    I was wondering if there is a way to tell revit to only show on a sheet only the wall compositions that are on that plan.
    Example : On my ground floor, I have my M1 Exterior wall and my C1 and C2 for my interior walls, so only these 3 wall compositions would show on that sheet. Then lets say on the 2nd level I have a M1 and a M2 exterior wall with 3 types of interior walls so my composition list would be longer.
    I guess I could do every type of wall in different legends and drag them one by one but it seems counterproductive.
    Thanks !
    Wall legends on each sheet? Usually they are on one sheet in either the details area or G sheets...
    I wouldn't have enough room on a sheet to have wall legends on each plan sheet.
      I did it with walls on a mid size building (63units from memory) using the live element phase method and it was a NIGHTMARE. Waaaay too much work. Ever since then it's been a legend sheet or two. You CAN overdo Revit, unless you have unlimited time on your hands.
