Problem on linking IFC in Revit 2017
    Hello all,
    I use the Revit 2017 and I want to Link an IFC file. It seems like the IFC file is linked (see attachments) but I cannot see anything! I have checked the imported categories in the V/G and I also have mapped an 'default template for IFC import'.
    Could please someone tell me how I can solve the above problem?
    Thank you in advance!
    Regards,
    Maria
    Check the phases. Even ifc has the phases
      I have the same phases.
        Have you checked the Phase Filters of view?
          Have you gone into 3D view and ZE'd ? Sometimes the IFC get placed miles away . . .
          And can you not select the IFC link in the browser and "show" ?
          If it still isn't found then go through the standard search for something hidden, is it on a closed workset, etc., etc.
          Kamran Mirza
            Hello,
            thank you for your answers! I have tried all the suggestions.
            -Check the 3D view ZE
            -The phase / phase filter
            -The V/G
            Any other suggestion?
              try this way instead - in revit click on "open" then go to "IFC"
              Once opened, save this model (it is now a *.rvt file)
              now link the revit model, rather than the IFC.
                Again the same problem!
                  visibility graphics "imported categories" make sure its ticked on
                    Yeah it is ticked on.
