White as Grey in Elevation - Drywall Material Issue
    Hello everyone,
    I have a drywall material and in elevation (shaded) it shows as true white. When I duplicate that EXACT material OR create a NEW material with the EXACT properties, it shows as a shaded grey. I can even place that duplicated material on the same wall family and it turns grey. I wish it to be white. There are no filters in my view.
    I can change the sun setting to 100% and make everything white however it does not answer the question as why one material is not effected by sun setting and one is, when the ONLY difference is the name. Why does drywall material stay white in shaded mode?
    Thank you!
    Do you have some sort of override in the view - either a filter or element override?
    chad
      No, I don`t.
        there is one tab in the material setting you havent shown and I suspect this is where your issue is.
        You need to go to the "graphics" tab. The "appearance" tab is for rendering, the graphics tab is where it will set your material shading/hatching in cut and projection for plans and elevations.
        Set this to white and I am pretty sure problem solved.
          My guess, without seeing the model, the material isn't actually applied to the model. It might be applied to the family, but that's to say it made its way to the model. Can you upload an example? Or just the door family?
          Greg McDowell Jr
          about.me/GMcDowellJr
