IFC & Classification Manager
    Hello,
    Using the Add-in Classification Manager, I have 'given' some Codes (Masterformat/Uniformat etc) in my elements. The problem is that when I export my project in IFC Format, and open it again in Revit I don't have anymore these Codes.
    IFC doesn't export shared parameters?
    Thank you in advance!
    Just a quick note. Round tripping is not supported by Buildingsmart
      You could use the following 'link' approach...
      https://www.youtube.com/watch?v=8J1C...ature=youtu.be
      The resultant geometry is not editable, but the parameters are imported.
      Also, it appears from the roadmap, importing parameters will be supported in the future: https://sourceforge.net/p/ifcexporte...?limit=25#b4c1
