Have any of you experienced a significant slow down in the time it takes to access these dialog boxes? This is 2016. And if so did you find the solution?
Object styles or VVG(View Visibility and Graphics) dialog takes a long time to open
Scott D. Brown, AIA | Senior Project Manager | Beck GroupTags: None
No. The only time I ever experienced this was when we had a project get corrupt through loading mfr content (see thread below), but that was a long time ago and Autodesk removed that feature.
Maybe check through your subcategories to see if anything is going haywire.
Is it isolated to one project or one machine? Sometimes I have found weird stuff like this isolated to corrupt windows user profiles after windows updates...
There are definately some funky things happening with this project, we are getting numerous parameters copied, ie a dozen "project zone" parameters, or "color name". And I'm seeing a ton of "imports in families" categories, not happy about this, I guess I've got to do some detective work and see whats getting loaded into our files. We did have someone from our dallas office putting in medical equipment, I'm concerned that maybe that content wasn't ours. Thanks for the help.Scott D. Brown, AIA | Senior Project Manager | Beck Group
Originally posted by sdbrownaia View PostThere are definately some funky things happening with this project, we are getting numerous parameters copied, ie a dozen "project zone" parameters, or "color name". And I'm seeing a ton of "imports in families" categories, not happy about this, I guess I've got to do some detective work and see whats getting loaded into our files. We did have someone from our dallas office putting in medical equipment, I'm concerned that maybe that content wasn't ours. Thanks for the help.
Imports in Families definitely doesnt sound good, but its not causing the Parameter thing. They are different issues.
Understood, the parameter thing has plagued this project since close to day one. But the slow down in the Object styles is more recent and I'm seeing a lot of cad layer names in imports in families. I've saved as all the families out of the project into a folder and will go thru the ones that look unfamiliar. Thanks for all the help.Scott D. Brown, AIA | Senior Project Manager | Beck Group
We ran into an odd issue today, which I want to share so this solution is out there but also to solicit ideas about why it might have happened.
...June 1, 2016, 11:20 PM -
We have a 230mb 2015 Revit model which suddenly and for all users, takes about 4 minutes to open VG. We've tried saving a new central, compacting, auditing,...June 1, 2016, 01:13 PM
Last Friday I had my Revit working fine in the am. I shutdown went home and when I attempted to open Revit 2016 it takes 10 minutes to open, and when...February 8, 2016, 01:07 PM
OK, Architect here, 20+ years using almost exclusively AutoCAD. I decided to test the waters with Revit by purchasing a copy of Revit LT 2014. I got a...September 20, 2013, 08:45 PM
Anybody could tell me what causes the project parameter to duplicate ? I have schedules set up for when I create assemblies and after the fabrication...December 16, 2016, 06:12 PM
Monumetric Footer In-screen
