Changing Vertical Alignment in Revision Schedule
    As per the title, is it possible to change the vertical alignment of entries in the revision schedule? My description is spanning multiple lines and everything else is aligned to the bottom, which I think looks dumb, so I want it to be aligned in the middle.
    I know it is possible to adjust a regular schedule in a project so in theory the revision schedule should be adjustable as well - possibly through Dynamo?
    https://knowledge.autodesk.com/searc...13F45-htm.html
    chad
