sweep did not work with me to draw cornice along roof
    i did sweep by drawing profile on side and sketch path but it faild with me i do not know maybe because there is two workplane i picked
    the method of wall sweep do not work except horizontal and vertical
    hope you can help me in that
    thanks in advance foe the help
    (notice:the image is owned to dzatto member)
    I used the fascia tool, along with model lines. Here's a thread on it. Post #22 by the one and only Martijn is an excellent tutorial, with pictures. That's exactly how I did it.
    For the porch, I used a wall sweep. The only reason I didn't use a wall sweep for the top area is because:
    1. The returns where the parapet breaks the fascia. There isn't a wall that is perpendicular to the main wall in that area, so a wall sweep wouldn't give me that slight return.
    2. The peaks themselves. They are created by editing the walls profile. Walls sweeps are only horizontal (that I know of), so it would cut horizontally across the peak.
    Both the wall sweep and the fascia are driven by the same profile. So, you will first need to create a profile family and load that into the project.
    dzatto
    "OMG I killed Revit"
    Dan
      awesome i tried fascia and it works with me thanks dzatto
        Let's keep the credits where they belong: Mark b first mentioned this trick in this post.
          Sorry. Yep, Mark was the originator. But you had more pretty pictures in your post to look at. :laugh:
          Dan
            Hey, Dan - I didn't know they were turning the Alamo into a get-hosed-&-lubed joint.
              That service is performed around back. :laugh:
              Dan
                Me love you long time, pardner. Y'all come back.
