PLEASE HELP ! Can't see my appearance properties
    Could someone please tell me how come i can't see my appearance properties? (the column on the right) I already reinstall twice but still can't solve the problem. Please help~Thank you!
    Did you do a Clean Uninstall before re-installing? You could also try to reset the user interface first...
      I tried the clean uninstall and reseting the user interface through the script provided. But it still doesn't work. Is there any other solution i can try? Thank you!!
        Not that I know of, sorry. You should file a support request with Autodesk.
          total longshot: turn off hardware acceleration?
            Issit possible because i am using the Chinese language pack of windows 7 home edition?
              That might be a problem... Did you also install the chinese version of Revit?
                Might also try reinstalling the Materials Library...
                  Yep...Language Pack issue....Change to English...
                    I am using RAC2012 (English) under Chinese Windows 7 Professional Edition. i tried installing the english language pack but it won't allow me to. Only the Ultimate edition and the Enterprise can do that. I tried reinstalling the material library as well.
