Batch printing to pdf
    Is there a way to batch print to pdf with auto file naming?
    What I need to do is to print all the sheets, (around 100) to individual pdfs. Thus, I do not want to name each one individually.
    How would one go about this? Is there a plugin?
    Use PDF Creator, it has batch print options that use the view name.
      https://www.xrev.com.au/products/Xrev-Transmit will pay for itself in an hour or two.
      *as in if you're plotting 100 sheets it'll save you an hour or two each time you use it
        We swear by xrev transmit - good value for money but there's lots of others available. https://www.xrev.com.au/products/Xrev-Transmit
        That he is mad, ’tis true. Tis true, ’tis pity,
        And pity ’tis ’tis true
