.ifc import problem
    .ifc import problem
    I'm having a hard time importing an .ifc file (structure) into revit arch 2011... I can import the same file into 2012 and it imports perfectly but when I attempt the import with 2011, the import is missing beams, columns, plates etc.
    is there a known workaround for this?
    thanks.
    tecton3d
