Linked Revit File Positioning
    I have a building floor plan in which there a several Linked Revit files (tenant spaces). one linked tenant space is in the correct position in the floor plan view, but when I switch to the Area plan the same tenant space is off by one foot. How can it be OK in one view but in a different location in another? Does this have something to do with how the files are linked? Help if you can.
    Nothing to do with how the file is linked. Are you looking at the same level in both views? Any chance everything in one of thise views has accidently been moved by a foot in either the host or linked model?
      Thanks for your reply. Turns out one of the s was moved which was causing the problem.
