Tag with ?
    Tag with ?
    I have uploaded a structural column tag that I am having an issue with. I can't get the ? to go away when the parameter is empty. You won't have this shared parameter, but you can switch the "BP-1" Label to equal comments and it will still show the ?. I have other column tags "comments" and when none is filled in it is just not showed just as it is supposed to.
    Any help?
    So I was informed that column tags have a really cool feature that requires them to have a line or filled region or something in them or the ?'s do this... how awesome is that :banghead::crazy::whiskey:
