Cut wall pattern issue
This topic is closed.
    I have a plan in which i wanted to set a cut pattern style to be applied to all walls, (vertical small) i set edited the pattern to align with element however it does not align with the orientation of th walls.
    What am I doing wrong?
    Juan Carlos Moreno
    Sisley Cosmetics
    [ATTACH]337[/ATTACH]
    I´ll bet you a cold :beer: that you´ve edited the wrong pattern, and the one used for the actual walls, are set to align with view - OR you have a view override on those walls
      well, I applied the cut pattern as an override
      Why does it not work this way?
      Juan Carlos Moreno
      Sisley Cosmetics
        It *should* work with an override - But am still thinking that you must be editing the wrong pattern, or accidently set the right one to "align with view"
          Sorry, mine won't work either with override on Align with Element...
            Thanks, somehow I did it again and it worked. I think I had edited the pattern through the override dialog and forgot to actually assign the pattern to the override
            Actually it was the fact that I assigned the pattern directly to the material of the wall then when I added the override it worked fine.
            Once I removed the pattern from the wall material then it changed again to aligned with view even though its set to align to element
            JCM
            Spanish Moderator
            Juan Carlos Moreno
            Sisley Cosmetics
              Here is an image with the settings i used and the result
              Juan Carlos Moreno
              Sisley Cosmetics
                this appeared on Revit Clinic today (coincidance ?)
                havn't had time to read it all but looks like it may help explain your situation. If not , he is always a good read.
                http://revitclinic.typepad.com/my_weblog/
                mark b
                Mark Balsom
                  Thanks for the link Mark! The info was right on. I had the detail set to fine so that is why it didn't work once I change it to coarse bam!
                  Juan Carlos Moreno
                  Sisley Cosmetics
                    Glad to help Juan.
                    Interesting article learn't something new there. Revit Clinic is always worth keepinig an eye on, they regularly post and always informative.
                    Quite a coincidance they posted that today. Must be your lucky day.:thumbsup:
                    Mark Balsom
