2017 Template
    2017 Template
    I have a project using a template that I have been working with in Revit 2016, but when I try to bring it into Revit 2017 it tells me that there are files that are corrupted and it shuts down. When I use the template by itself in 2017, most of the families are not available. Is there a way to fix this other than manually loading all of the families back in?
    Have you tried using the "Audit" feature when you go to open the template?
    Alex Page
    RevitWorks Ltd
