Change Key Schedule Grouping
    Is there any way to change the "Key Name" parameter in a Key Schedule?
    I'm talking about the Grouping of that parameter.
    I know I can change the name of it from the Schedule's Properties, but the parameter itself ends up in the "Identity Data" grouping.
    I'd like to move it to the same parameter grouping that all the rest of the parameters in that schedule are under.
    But the Key Name parameter doesn't seem to show up anywhere else.
    I can't Edit the parameter's properties from the schedule, and it doesn't show up in Project Parameters.
    This one:
    Dave Plumb
    BWBR Architects; St Paul, MN
