Column headers with same name not combinging in a Schedule
    Hey Everyone,
    I am using two fan coil units that are nearly identical, one is horizontal and the other is vertical. All of the fields with identical names and parameter data combine in the schedule, except for these two fields. Any ideas why these fields do not combine?
    I tried creating a calculated value to merge the two fields but Revit say: "Formula is ambiguous because the schedule includes more than one field named Sensible Heating Capacity."
    -Jeff
