HEEEELP!!!!! Underlay+Ceiling
This topic is closed.
    I really need some help here guys.
    This is a building being modeled by a user in my office.
    I have posted about this previously and now it is getting urgent.
    http://www.revitforum.org/showthread...ng-in-underlay
    If you look at t/o level two and try to set the underlay to the same levels ceiling plan it does not work.
    The same is done to levels 3 and 4 ................ and here it works.
    Could someone help with a fix or a reason as to why this won't work?
    I have set the ceilings that should showing to a cloer to clarify.
    RED+ 2nd floor
    Blue= #rd floor
    Thank you in advance
    MW
    Try using the 02-T/O 2ND FLOOR as the underlay instead of the T/O 2ND FLOOR
    It seems that you have a different plan as your source for the ceiling plan
    hth
    Juan Carlos Moreno
    Sisley Cosmetics
      COuld you post (part of) the file? Would like to take a stab at it, but this is kinda hard without the use of Revit itself. I believe we covered all the usual suspects by now.
        Hi Martjin.
        i tried to load the file but it is a bit to big right now.
        Will have to try and reduce tonight or find another way to get to you.
        We can try dropbox.
        MW
          hth
          Hi Juan
          Dont realy get what you mean. Sorry.
          The reason why you can see the t/o 2nd floor (bathroom fixtures) showing in the t/o 2nd floor RCP is cause I had it switched on as the underlay earlier to check other ways around the issue.
          please elaborate on your thoughts casue I need it.
          Thanks
          Cheers
          MW
            How big is the file now ? We could temporarily allow a large file to be uploaded if needed - I understand that it´s getting urgent :beer:
              Its at 52 MB right now.
              I could chop a few levels of and see what I get.
              MW
                Originally posted by RabbitHole View Post
                Hi Juan
                Thanks
                Cheers
                Well, I saw from the screen capture that the plan you had as the Underlay was labeled T/O 2ND FLOOR and the view you were in, was labeled 02-T/O 2ND FLOOR so I thought that maybe there was another plan view with a very similar name as the one you need. and perhaps the settings for the view range or visibility settings you were changing might not be for the right view.
                Juan Carlos Moreno
                Sisley Cosmetics
                  Oh ok. Make sence. I had the underlay set to the same level but I am referencing the Ceiling Plan.
                  Check this blog post
                  http://revitclinic.typepad.com/my_we...ientation.html
                  And this video
                  http://www.screencast.com/users/JSmi...b-c50bcda57bf4
                  MW
                    OMG 52MB is killer for a DB to handle
                    -Alex Cunningham
