Parameter relate Room Area
    Hi everybody,
    I am in charge on a PM Project. The Room Area of Revit very useful to calculate the Cost Estimate.
    I want to add a parameter in Room ( Example the Name Parameter is Masonry) which it's value is alway equal with Room Area (when I change the design, the Room Area will change and this parameter will equal also)
    I really need your training.
    Thank you.
    I'm a little confused. Are you trying to have a parameter changed based on the area?
