We're working on updating our LOD document. Part of it is a spreadsheet listing the Uniformat numbers for all of the Revit Elements.
Unfortunately, Uniformat lacks a code for Rooms.
What have you used to classify them?
Dave Plumb
BWBR Architects; St Paul, MN
I have not come across this problem before.
Since rooms aren't part of the physical building, they don't fit nicely into Uniformat (they also don't appear in the specifications...). The best I can think of is to put them in C10 (Interior Construction), but you definitely don't want them to be confused with something that is real.
Uniformat doesn't lack a code for rooms, that is not the intended purpose of Uniformat, which are elements.
Walls, floors, ceilings, doors, windows, columns - those elements make up rooms / defined spaces.
Table 13 - Spaces by Function is more likely what you're after.
Unfortunately, you can't use the assembly code txt file to do this and you'd have to create your own parameter to hold that info.
I'm intrigued how Table 13 can be used effectively on projects.
(Revit) Rooms/Spaces get the appropriate code shoehorned into them using a SP as you suggest then someone using software that's actually useful for relating things spatially (thinking SMC here more than Navisworks) can do "validation" to ensure square pegs are filling square holes?
I'm not familiar enough with SMC to understand how that would work. What type of validation could happen that couldn't happen in 2D?
If you've seen a demo of Revit MEP and Spaces or if you have used Spaces yourself then you may already be familiar with the new Rooms version of Place...
I am trying to assemble a program for a client. I want to use the massing aspect of Revit. I have bathrooms, meeting rooms, offices, cafeteria, etc. as...
We have been working on a large scale residential project, in which the suites were formed as groups. Recently, we changed all these groups, and in the...
So the more CD projects I'm getting my hands into and trying to make thinks streamlined the more I realize I'm using rooms only to assign a designed space...
December 26, 2016, 04:36 AM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
