Problems acquiring coordinates in two revit models
    Good night,
    At the moment I am having some problems acquiring the coordinates of an architectural model that is made by phases. I have two architectural models. One of them is the existing building made by cloud points. The other one, is a smaller model that is a finished phase 3 after demolishing some walls and floors of the existing one.
    I don´t have any problems when I open the existing model and link the phase 3 model by shared coordinates. They appear exactly in the position that they should be. The problems appear when I link the existing model to my MEP revit model. The process that I do is this:
    - In my MEP model I link the existing architectural model origin to origin because is the master model that has the coordinates that I have to use.
    - I acquire the coordinates of the existing model to my MEP project.
    - I link the Phase 3 architectural model by shared coordinates and it appears in another place, far away from it should be.
    I have tried to do the process nesting both architectural models into my MEP model, changing the properties of the link to Attachment instead of overlay. But it only appears the existing one and I can´t see the phase 3 model.
    I hope that you can help me,
    Thank you very much
    Originally posted by ducke1991 View Post
    Good night,
    Thank you very much
    Anyone has an idea of which can be the problem??. Thanks I am still struggling with this.
    Sent from my SM-G900F using Tapatalk
