Revit 2014 not rendering on quadro M2000 graphics card
    I recently purchased an nVidia quadro M2000 graphics card. Hardware acceleration is enabled, however the version of Revit I am using does show the message that the card is not on the list ( as of the release of Revit I am assuming as it works on 2016)
    As the 3D hardware acceleration is enabled, does anyone have any troubleshooting tips on finding why it is using the emulated during the render process instead of the graphics card? Are there some other options that I need to set?
    Windows 7 Professional / Revit 2014
    3 Attached Images
    Thank you in advance,
    Chris Burchett
    I do not believe Revit 2014 utilizes a GPU at all for rendering. Also any of the M series cards are considered too new for 2014 according to Autodesk's site.
    Autodesk - Certified Hardware - Find Recommended Hardware
    That being said, it should run fine. I seem to remember a major architectural change from the K series to M series that might cause conflicts though, but again, it should work fine.
    RB Cameron, AIA, LEED AP, EDAC, NCARB
    Architect - Parametric Designer - Visualization Instructor
    Download Healthcare Revit Models
    Download Revit+3dsMax Models
    widgetinstance 211 (Related Topics) skipped due to lack of content & hide_module_if_empty option.
