I have use split surface to change some heights of my topografy!
Is there any way in a section to see the real topografy line in order to draw a line on top and schow how it was before?
This is what i wanna do. If theres a way to hide the slpit surfaces because i moved the points in differnet level..see the real topografy level.. and draw it with a line like the blue line i have there!
thanks
You can try creating existing toposurface and put it under existing phase. Put the new one under New construction. Then manipulate with view properties line weight and other graphics?
See if it works...!
Sent from my iPhone using Tapatalk Pro
" Purpose may point you in the right direction but it's passion that propels you" - Travis McAshan
One topography as existing and one as proposed. Then choose phase filter to show existing, draw over existing, then turn phase filter back to proposed, ending up with detail line sitting over proposed. What i see as the best way of showing natural ground level/line, (NGL).
In section and elevation, I'd like to have level heads on both sides of the model. In plan, section mark can be split, and the line can be modified not...
I seem to have a peculiar problem where I cut a section and the rafter prints with a double line, one line being the solid line and another line coming...
I'm getting a problem where my section lines are not showing their correct setting ie clip with line. They keep reseting themselves to no clip. Any idea's...
I've created a thick dashed blue line for a project but it doesn't stand out very well, but it needs to be blue, does anyone know...
December 9, 2014, 02:41 AM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
