Rotating label text issues
    I am having trouble with the rotation of a label in an elevation mark. Some into the project that would allow you to understand the issue better: Basically, We have all the sheeted floorplans rotated counter clockwise at 90 degrees, in order to fit better on the sheet. As a result, all of the labels are oriented incorrectly and need to be turned 90 degrees clockwise to offset that rotation (horizontal on the sheet). Therefore, I am making custom elevation and room tags that are oriented to the sheet rather than the view.
    That being said, I am having trouble with the center label in the interior elevations. No matter what direction I rotate the center label, it only shows up as being rotated counterclockwise 90 degrees, or 180 degrees. i have unchecked "keep text readable" but still having issues.
    Thanks
Name:	Rotated Interior Elevation Callout.jpg
ID:	392270Click image for larger version
    Originally posted by katewood1989 View Post
    I am having trouble with the rotation of a label in an elevation mark. Some into the project that would allow you to understand the issue better: Basically, We have all the sheeted floorplans are rotated counter clock wise 90 degrees in order to fit better on the sheet, as a result, all of the labels oriented incorrectly and need to be turned 90 degrees clockwise to offset that rotation and be horizontal on the sheet. Therefore, I am making custom elevation and room tags that are oriented to the sheet rather than the view.
    Thanks
    Make sure you choose the Elevation Mark that is rotated, see image.
    Last edited by Charles Karl; January 26, 2017, 03:45 PM. Reason: Forgot to mension to duplicate the elevation type before choosing the rotated marker
    Bettisworth North
