Watermark
    Watermark
    Hi All,
    I can print my drawings to pdf and add a watermark in Acrobat (pic 1), but I wonder if watermark can be added in Revit, or if the text (letters) can be transparent, so everything behind is visible (pic 2). Thanks.
    Well, it can be:
    Create a drafting view
    Sketch the text using Filled Regions with a grey solid fill set to transparent.
    On you sheets, place this over the text and it should work.
      ...yeah, I was thinking about it, ...eventually gave up on it as time consuming option, hoping for better more flexible solution - 'real' text that can be updated as needed. It looks like Acrobat is the way to go then.
      ...maybe in 2013
      Thanks Martijn :beer:
        Wrote a post about a watermark technique back in January 2006 and the good news is it still works in 2012. Work around warning, it involves a dwg file with the text and using a legend view but it does work.
          Isn't that going to result in the dreaded "as indicated" view scale in most cases...
          Chris Price
          Co Founder | BIM Manager | Product Designer | B.Arch (QUT)
          Xrev Revit API Add-ins | Revit Rants
            ...maybe in 2013
            Well, to set up maybe. But the drafting views can be saved out to your template so you can reuse them
              True, but I thought it would be possible with true text watermark somehow.
              Steve's idea is not quite working for me.
              ...I think I stick with Acrobat for now.
              Thanks guys!
                Yep, if you show that on the sheet anyway. With a view title the scale is already there, why show it again...
                For the technique to work I believe the legend needs to be wireframe.
