Revit crashed and displayed a prompt that allowed me to save a recovery file before it terminated. However, looking at the file size of this recovery .rvt file, it is 100MB less than the central. I'm hesitant to sync back to central. Is there a reason there is a discrepancy between file sizes? Will syncing this recovery model back to central corrupt it?
Revit local recovery file significantly smaller than central file after crash
I almost never used the Recovery files in that other program. They were pretty much guaranteed to be corrupt.
Conversely, I've almost never had a problem with a Revit Recovery file.
Of course, you'll want to open you Local Copy and poke around a bit to make sure nothing obvious is missing, but you're probably fine.
Don't worry abou the file size. Revit stores a lot of Undo information within the .rvt file and that's probably all you "lost."
After a few SWCs, it'll be back up to the original size again.
You can see the same effect if you do a SaveAs and create new Central. That'll make is smaller, too.
Oh, and when you open your Local check the Audit box.
Revit won't tell you anything, but it will fix any errors it finds.Dave Plumb
BWBR Architects; St Paul, MN
In need of some help here. Me and my partner have just started using revit recently for our new project and we keep having problems with corrupted files....February 26, 2016, 04:06 PM
I'm curious - I've noticed this before and never really thought anything of it, but I'd like to know more.
I have a project file, probably...-
June 20, 2012, 01:56 PM -
I regularly read the Southern Arizona Revit User Group's blog. A recent post poked me in the eye and I thought I'd respond to it here. Here's the bit...
Channel: Blog Feeds
July 12, 2011, 03:00 PM -
Dear colleagues,
I've got a problem with my central file in my company:
When I want to open the central file and get an local...-
Channel: Worksharing and Cloud Coordination
October 17, 2019, 10:38 AM -
Ive got a revit file, I just want to make a local file but I cant it keeps wanting to be a central file after I open it (detach from central)
Channel: MEP - General
January 8, 2016, 09:07 AM -
Monumetric Footer In-screen
