Section Box Orientation
    Does anyone know how I adjust the section box so it runs in the same orientation of the building?
    See attached.
    EDIT: NVM http://www.cad-addict.com/2013/07/re...ction-box.html
    Domsib
    Revit MEP - 1 Day at a time...
    In the Top view you can select the section box and rotate it - either by using the Modify>Rotate commands from the ribbon or by using the rotate symbol that should be visible on the box in this view. I prefer the Modify>Rotate command as this gives you the option to place the centre of rotation.
    See attached.
