Trouble with Formula
    Hi All,
    I have tried my hardest to deal with a simple enough formula, but cannot get the formatting correct for it to generate what I need.
    I have a quantity parameter which I need to mutiply the amount by, depending on whether the LHS or RHS is on or they are both off. So I have 3 scenarios:
    • Both on, which would require the quantity parameter to be x by 2.
    • 1 on and 1 off, which require the quantity parameter to be x by 1. I.e no change from the quantity number
    • Both off, which requires the quantity parameter to return a 0.
    Can anyone help create the correct formula for this?
    Cheers
    LHS (Y/N)
    RHS (Y/N)
    Q_calc (Area) (where your family is reporting it's original number)
    LHS_factor (number) if(LHS,1,0)
    RHS_factor (number) if(RHS,1,0)
    factor (number) = LHS_factor+RHS_factor
    Q_report (Area) = Q_calc * factor
    could be a bit less parameters if you nest the formula's.
      Originally posted by Bjorn_K View Post
      LHS (Y/N)
      RHS (Y/N)
      Thanks, I shall try this now!
        Boom, it worked.
        Solved. Simplifiying is key!
