Funiture Colour in Plan
    hello everyone...how to change display colour in plan of architectural components that comes with revit ? for eg..the sitting unit in living room is custom family made by me which shows perfect colour as per material i applied but in case of revit components despite of applied materials it shows all white in plan ...can anyone help regarding same ..
    Thanks in advance
    One way is to place a camera view perpendicular to the plan and select the realistic display graphic. Or you can render that camera view.
      A lot of the older content is built with masking regions and the geometry turned off in plan. Edit the family, delete the masking regions from the plan view, then select the geometry you need to see and turn it on, then load back into your model.
      chad
