Does anybody know how to make a User Keynote switch to User based from Element based?
    I have 2 different projects using the same "User" keynote family. In one project it will only work as an "element" based keynote...and the selection (element or user) is grayed out and will not let me change it. My other project uses the keynote as "User" based.
    Where is the setting for this?
    "User Keynote" and "Element Keynote" are separate commands. They can both be used in any given project. You cannot change an existing keynote from one to the other.
      When I try to use "User Keynote" it still keeps implementing itself as "By element".
      Not sure why or how this is happening, because I am using the "User Keynote" command, not the "Element Keynote" command.
        Wow, nobody else eh?!
          Can you provide more detail, some screenshots might help.
          Note.
          A "user keynote" while not pulling its value from a object is still hosted to the object
          not sure what your running into...
