Lines appearing when printing to pdf / exporting to image
    Hi guys.
    Like the title says lines (that aren't there in the model) are appearing when printed to pdf or exported to image. Any idea why this is ? I'll attach two pictures showing the lines inside the yellow circles.
    If there is a thread here here about this you could tell me where and I'll delete this one.
    Thanx !
    Used another pdf writer?
      Originally posted by HSG11 View Post
      Hi guys.
      Thanx !
      This has been an issue since at least Revit 2010, why exactly I could never confirm. It seams to happen when exporting (or printing to PDF) in large high resolution images, 300dpi plus.
      I've had the issue mostly with PDF and jpeg, never (that I recall) with png if that helps
