Custom Prject Browser Issue
    Hello, I am creating a custom project browser. I did this by creating two project parameters (view category and view subcategory). I would like it to work like the OTB Revit browser where when creating a floor plan it will automatically be placed in the floor plan category. With the browser that I have created, the plans comes in to the browser as a question mark (???) and I must assign the category and subcategory before the plan will move to the correct spot in the browser. Is there a way to make my created browser behave in the same manner as the OTB Revit browser? Thank You.
    I believe if you make the view type have a view template associated and the view category parameter part of the template then it would come in the way you are asking.
    Good luck
      That worked! Thanks for your help.
