Relinquish when I say relinquish
    I've seen this occasionally, but never figured out the cause
    Sometime is you quit a project, don't save and Relinquish, Revit doesn't relinquish everything.
    This just happened to me. Unfortunately, I didn't think to take ascreen shot, but the Journal file says:
    Jrn.Data "TaskDialogResult" _
    , "You will remain the borrower of the elements that you changed in these worksets:" & vbCrLf & "Project Info" & vbCrLf & "Shared Parameters" & vbCrLf & "" & vbCrLf & "", _
    "Close", "IDCLOSE"
    'E 17-Jan-2017 11:48:35.625; 0:<
    I said Relinquish, so why didn't it Relinquish?
    Now I have to open the file again just to quit out of it.
    The only thing I did that was unusual was that I did an Undo all the way back just before I closed.
    Maybe that flushes out the Relinquish?
    Dave Plumb
    BWBR Architects; St Paul, MN
