Docked 3rd party apps
    Is there any way to specify what order your Palettes come in?
    We've got the Kiwi Codes Family Browser and most people have it docked as a Tab in the same palette as the Project Browser.
    The problem is that when you open a project, the KCFB is always the active Tab.
    Sadly, a lot of people just click on the X and close KCFB instead of leaving it there under the Project Browser.
    Why, I don't know. It's one click either way.
    I assume this happens because Add-Ins gets loaded after the rest of the UI.
    So, is there a way to set the Project Browser as the active Tab at open?
    Dave Plumb
    BWBR Architects; St Paul, MN
