Just curious about the use of match lines; are they necessary in the BIM world at all? My thought is that a good key plan along with the use of scope boxes would be enough. Any thoughts?
Are Match Lines Relevant
Matchlines don't have anything to do with BIM. They a drafting entity. An aid for reading drawing sets. In my experience, key plans usually indicate the area shown on a particular sheet and the matchlines indicate what sheet to go to for the continuation. I see you have combined those bits of information into your key plan. I'd say matchlines still have a place in the drafting world.
Originally posted by RobDraw View PostMatchlines don't have anything to do with BIM. They a drafting entity. An aid for reading drawing sets. In my experience, key plans usually indicate the area shown on a particular sheet and the matchlines indicate what sheet to go to for the continuation. I see you have combined those bits of information into your key plan. I'd say matchlines still have a place in the drafting world.Bettisworth North
A match line aids in delineating between sheets for manual quantity take-off/pricing. Think along the lines of receptacles, lights, diffusers, etc. It is increasingly important with BIM as items show on both sides of the match line, which is a departure from the CAD days.Last edited by kubsix; January 16, 2017, 12:10 PM.John Karben | IMEG Corp.
Matchlines are required by some of the old school folks in my office. A good keyplan as shown IMO would be fine. BTW, how did you make that keyplan? Is that a legend ? I've always struggled making keyplans because i want to show say the ground level but a view isn't placeable on more than one sheet. Do i need to export to cad and then link it back in? that seems ridiculous.
Originally posted by Charles Karl View PostJust curious about the use of match lines; are they necessary in the BIM world at all? My thought is that a good key plan along with the use of scope boxes would be enough. Any thoughts?
Originally posted by kubsix View PostA match line aids in delineating between sheets for manual quantity take-off/pricing. Think along the lines of receptacles, lights, diffusers, etc. It is increasingly important with BIM as items show on both sides of the match line, which is a departure from the CAD days.Bettisworth North
Originally posted by glenbob305 View PostMatchlines are required by some of the old school folks in my office. A good keyplan as shown IMO would be fine. BTW, how did you make that keyplan? Is that a legend ? I've always struggled making keyplans because i want to show say the ground level but a view isn't placeable on more than one sheet. Do i need to export to cad and then link it back in? that seems ridiculous.Bettisworth North
I make the keyplan a generic annotation with filled regions tied to visibility parameters. That gets placed in the titleblock family and linked to similar parameters in the titleblock. This works well when you have a lot of sheets referencing the same series of plan areas, especially across disciplines.
Originally posted by Charles Karl View PostThe bottom line is that one can easily flip though a series of sheets with the aid of an accurate keyplan.I'm retired, if you don't like it, go around!
Coming from the MEP side, I have had matchlines that would divide a building or a wing and depending on the trade/system may vary slightly. For instance, a room on a duct plan might want to be on one side of the matchline because the duct runs end there and on the lighting might want to be on the other side because of circuiting. At a small scale like a key plan, those slight differences would not be discernible.
Right now, I go "create new sheet", choose our project-specific parametric titleblock (check on key plan/north arrow/etc), choose discipline,...March 20, 2013, 07:28 PM
I know Revit has the automatic alignment tools for views dropped onto a sheet but does it offer any sort of tool for making sure my plans show up in the...June 16, 2014, 06:41 PM
I have been asked to come up with a solution to make our key plans work like shown in the NSC standards.
I need to have: (Placed on every...February 8, 2011, 08:40 PM -
Applies to: - All Verticals
New Feature / Problem:
The ability to duplicate a sheet layout and change settings/swap views to create...-
Channel: Wish Lists / Feature Requests
December 19, 2013, 03:55 PM -
Attached are some area sep lines, set up using the 'area rules'. So they automatically snap to the middle / outside of wall, which can be nice.
...September 22, 2011, 10:00 PM
Monumetric Footer In-screen
