I could use a few suggestions on creating a curved railing. I've tried a sweep in a "model in place" Generic Model, but I can not get the path to recognize the curved surface.
The curved surface in the image is a mass with a divided surface onto which I drew a model line (3D Spline). I was hoping to use it as a reference to create the rail.
Thank you, I like that technique...wish I could do it without the facets....I used (50) on mine and it is pretty smooth, but seems like a bit more work (and poly's) than should be necessary. Very good for now though!
"More" of an ellipse? Or an ellipse? Can you post the file here, so we can look at it? I dont see any reason to not use a Railing, yet. :shrug:
Because you draw or pick a line if it's an ellipse. It seems that the railing tool (or the stair tool (even stair by sketch)) doesn't work with shapes other than line or arc.
If it's modeled (currently) as a *true ellipse* then break it down in to an approximating of arcs, and get on with modeling it with the railing tool. Using an adaptive component just to keep it 100% pure ellipse, is a bit... silly.
I understand the technical limitations. Still no point to massing it out.
The stair...which doesn't meet any building code that I know of...is in the shape of an airplane foil. I could not use the stair tool to create at it as there are many different tread shapes. The treads are individual generic models and sit on sleepers not stringers. I saw a sweep used as an alternate method, but the profile does not stay parallel with the floor. The adaptive rail worked perfect, but is a bit more time to create and it is segmented of course.
Can you share the procedure for using the railing tool? I understand following a series of arcs, but how do you define the upper and lower limits?
Is there any way of achiving this type of railing for a stair (see images below)? As you can see, the railing stop at the landing (last thread) of the...
I am looking to create a railing for a multistorey stair only for the inner part of the staircase. To get two separate - inner and...
March 16, 2017, 03:09 PM
We process personal data about users of our site, through the use of cookies and other technologies, to deliver our services, personalize advertising, and to analyze site activity. We may share certain information about our users with our advertising and analytics partners. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
