Light fixtures partially "buried" in walls on RCP
    Anybody have any ideas about why all of my wall based light fixtures are "partially buried" in the walls on my reflected ceiling plans?
    The fixtures are wall hosted based. I have tried to rearrange the core/substrate/finish on my walls to see if that helps (doesn't). So I have run out of ideas. Looking forward to seeing what I am overlooking here (ha!)
    Is there an instance or type parameter for the fitting that determines their protrusion from the wall. Other than that, have you had a peek in the Family Edit to see if their Geometry is constrained to the wall face reference plane?
    Kind Regards,
    Ian
    The Complete Beginner's Guide to Autodesk Revit:
    www.bimscape.com/revit
