For 3d views, is there any setting in Revit that would allow the transparent materials (glass for example) to be rendered as solid instead of transparent? I have several 3d views of my building, and I don't want to see all the interior stuff behind the glass. Is there any kind of global setting in revit that would allow me to do this without having to filter out all the interior stuff?
Transparent materials rendered as solid in 3d views?
I'm not aware of a global setting. You have to swap materials (or appearance assets within the material). I typically assign a "Default <family type> Glazing" material (Door, Window, Storefront, etc) in my families, and then override that material in the project if desired. If you need or want to automate material swapping with Dynamo, there's a "clay rendering look" method here: (it's the second topic / code block)
playing with materials in dynamo while drinking heavily | archi-lab
- - - Updated - - -
http://archi-lab.net/playing-with-materials-in-dynamo-while-drinking-heavily/Chris Ellersick
Could someone explain me Revit materials theory? Why is it different in 3d view compared with front view? Glass in particular. When it's 3d it appears...
January 11, 2016, 03:42 PM -
I have a clear space outlined above my conveyor. I am using glass as the clear space. I am creating a new material asset, and replacing the glass format....
Channel: Rendering and Gallery
August 31, 2018, 02:51 PM -
Hello!
For family creation, Normaly do you determine material to the object in family creation? or Do you attach material to the object in the project?...-
October 9, 2012, 11:22 PM -
Hi there. I saw how to save customised material in 'Appearence' tab (3D rendering appearence) as 'my material' (like own library). But i am wondering...October 9, 2012, 11:58 AM
Hello all,
Very new to revit.
For my project, I just created a new material, assign it to a family, and all looked good. Creating a new family...-
December 18, 2018, 01:44 PM -
Monumetric Footer In-screen
