how to scale component (family type is playground )
    Hi i am facing problem of rescaling the component i want it to be 28 *12 instead of 100*70 for playground when i change length and width in dimension the 2d is distorted as you can see in the image all i need is to rescale all lines or to avoid the problem happened to me
    every shape has to be constrained by parameters. Than you put some formula at the secondary shapes parameters so you can have the values of this parameters as proportional with the width and height of the big shapes.So when you modify one parameter the others adapt them self.
      thanks gaby the problem is i can not apply what you have said ,although i understood basics of families by videos i followed (this playground is available on Rac 2011 under site category there is playground )
        You should read the Revit Families Guide - And pay special attention to the "Dimensioning" and "Parameters" sections
