But revit keeps telling me that the reporting parameter dim must be attached to a host object or something like that.I can't seem to find a good example of what that mean in order to overcome this problem. I am making a good family for which I want to use a reporting parameter to return the clear opening (Life Safety stuff) Can someone please help me with an example?Thanks,
Help, Need to use reporting instance parameter in in formula
I need to use the inverse COS (COS-1) in a formula for revit, can someone please tell me the right syntax how revit needs this?
September 11, 2020, 02:49 PM -
I've got a formula to change the model number depending on an integer the user selects. The integer parameter has to be an instance parameter. But,...
November 6, 2013, 10:06 PM -
I am trying to write a formula for Revit that does the following:
(IF (Parameter 1 is ticked) AND (Parameter 2 is ticked)...-
October 14, 2015, 10:34 AM -
Hi there, this question seems easy, bu it isnt.
I've created the CSV table.csv with all the parameters uasefull for my reduction idro-fitting family....-
July 12, 2016, 09:39 AM -
Looking for some help. Keep getting the following message when trying to use a reporting parameter in a a formula. Can't seem to find any clear documentation...
December 15, 2010, 07:16 PM -
Monumetric Footer In-screen
