how to make custom selection showing in 3d ?
    Hello again every memebers here i need to know if it is possible to show partial display in 3d on specific area mean i do not have to load every time the whole 3d for heavy loading purposes here is example of other programme that show partial display i need to know this feature because sometime you need how shape of window or how shape of door look like with a material
    A few ways comes to mind.
    1. Go to a 3D view, then in properties, turn on the section box. You can then select the box and cut away the view. The only issue is it must stay as a box. So you can't do a wierd angle.
    2. In the project browser, select the 3D view. Right click and make a duplicate. Now, open the duplicate and turn off all the things you don't want. For example, I do this and only turn on my steel framing. That way I can easily see my framing in 3D when I'm designing it. I rename this view framing and it's always there, ready for me to use without having to mess with the original 3D view.
    3. Set up a camera and pretty much do the same thing.
    Dan
      Now I like these kind of postings... Simple question, with an example. :thumbsup:
      There's a few things you can do here:
      1. Use a scope box. Open a new 3D View, orient it as you like and in the View Properties turn on the Scope Box. This is like a 3D Crop boundary that let's you crop the 3D view to the extents you'd like
      2. Open a new 3D View and hide all elements you don't want to see. This gives you somewhat more control of which elements you want to hide but can be a lot of work in big projects.
      Anyway, when done, freeze the view and you can tag and dimension the 3D elements...
