Placing In-Place Families in Legend view
    Hello Everyone, My first post and I would like to extend my best compliments to the 'Revit Forum' team for the great resource provided here; now ill get right to it. How does one put in-place family plan, elevations, etc into the legend view. It is simple enough to do with regular families but it seems the the in-place family requires some other method.
    Also, how does one put 3D views of a regular family on the legend view?
    Thanks in Advance
    HAA
    Hi Hammad, welcome and thanks for the kind words.
    What you are trying to accomplish is not possible, but do a search on the forum for "Phase Before", and you should find a workaround (Else let us know)
      Hi Hammad,
      I have a workaround for placing in-place family on legend view. Simply save your in-place family as a family (rfa file) then load it in your project; legend detail component should be available.
      To save your in-place family as a true family, edit in-place, make a group of all the elements, select it then go to save as, librairy, group, you will see that the extension is rfa.
      (credits to this blog http://whatrevitwants.blogspot.com/2...or-use-in.html and also this older one (previous ;-) ?) from a French fellow http://revitmastering.blogspot.com/2...e-externe.html )
      For 3d in legend view, should it be? legend view are mostly designed to be plan view legend. you may prefer to have a nice 3d view frozen with annotations. my 2 cts....
      Julien
      P. DAC
