Pdf print bug
This topic is closed.
    Pdf print bug
    Does anyone know why when I print a full set of plans to PDFs and combine it in a single file, it prints everything correctly. However, once the printing dialog for adobe PDFs closes, revit tries to print each sheet individually and i have to start canceling it sheet by sheet?
    Juan Carlos Moreno
    Sisley Cosmetics
    I experience the same thing sometimes. I've tried a few different pdf writers with the same results. Usually it happens when the memory resources get strained (we have 8 GB of RAM), if I close out revit and let the memory clear it will usually print fine after that.
      Thanks I'll give that a try
      Juan Carlos Moreno
      Sisley Cosmetics
        Got this issue sometimes, my answer is that I never combine sheets with Revit but do it with the pdf printer (PdfCreator for instance).
        For memory, options in the pdf printer should be set to reduce dpi for the document.
        Julien
        P. DAC
