Hello,
I would like to start to create a Revit template.
First of all I have found that the way to create a template is from R menu > create new project template. Is it the way? I want to say, that after you need to just delete the default settings and you to add your families and to define your parameters?
Secondly, I have found that there are many basic items that a 'good' template needs. Can someone give me a guideline from which point to start?
Thank you in advance!!
